kbkindle
- Joined
- Mar 2, 2005
- 27
i have a teleflex gas gauge to replace the gas gauge on a ranger bass boat that has yamaha multi function gauges here is how i wired the new gauge
found the hot wire or pink wire from sending unit and cut it under dash and hooked to new gauge that has S TERMINAL then found a hot wire under dash with key on and connected to the I TERMINAL on the light unit it has a push on tab i found a ground under dash pluged it on the light and the gas gauge went to full that is what gas there is i just filled tank it did not go past full just to full the only thing is the light in gauge does not work no big deal but if i take bulb out then there is no ground connection and gauge goes past full like it would if some thing is wrong what have i done incorrectly as the light does not work.
this is my guess would like to know if this is my problem should i ground the wire to center post that would be the other half of light fixture and run another hot wire to the other side of light unit thanks in advance
