Teleflex Morse System Mounting Problem
I'm buying the Teleflex Morse system with dual 14ft cables, and i can't figure out how to mount it. I need to set it up so there is one cable on each side of the boat, so its like the old ride guide dual push pull systems. Any ideas?
Dhadley
Re: Teleflex Morse System Mounting Problem
Not gonna happen. The new "dual cable" setups from T-flex have one rack with 2 parallel cables. Just bite the bullet and get a dual Ride Guide system. Yes, they're over priced and over engineered but that's the only opposite entry system I know of. I looked for months for one for the Hydrostream. Finally gave up and put in a RG.
Dhadley -
I've been looking for a replacement system or at least the cables for my hydrostream for a while now. Could you tell me where you bought it? I need 14 ft replacement cables. Also, does it matter if i use cables that are 15 or 16 ft long? I'd appreciate any help you could give me. Thanks.
Dhadley
I bought the system used from a guy on scream & fly. No cables. Then went to the Merc guy and ordered cables.
