I have been trying everything I can for the last 2 days trying to disconnect the steering cable from the helm. I am having zero luck in doing so. I remove the pin like it says to on the tag. When I insert the pin into the release hole it does absolutely nothing, doesn't budge at all. When I look at the hole while pushing the pin into it it looks like it is just a hole with metal behind it. And it has no movement. I'm wanting to remove it so I can take the dash out to recarpet my boat. It is in the way of some carpet. I have watched multiple videos and looked at multiple posts and none have helped. Thank you for your help.
