The tachometer on my 2002 4 stroke efi 60hp jet shows between 1200 and 1800 rpm when the motor is shut off. When idling, it reads about 1200 to 1500 rpm. The motor has no problems running up to 6000 rpm on that tach, and when pushed for just a few seconds will easily pull up to 6300 rpm. Is it safe to assume that I'm reading about 500 rpm more than the motor is actually spinning (idle is set at 800)? Is there a fix for this Teleflex tach, or just replace it? Thanks!
