BlackPointBoater
- Joined
- May 7, 2020
- 2
Having an odd issue with my outboard. The tell tale mostly spits steam when the outboard is in neutral or at slow speeds. If I give it speed or use the warm start lever at full crank for a few moments, it will eventually start spitting a strong stream. This stream will then maintain at a lower speed and even neutral for a few minutes, but eventually reverts to steam, unless I maintain speed.
I have had one instance where the motor must have overheated, and shut off for about 10 minutes.
Any idea what this could be, or where I should looked first?
Thank you!
Thank you!
