Tell-tale on '66, 6hp 'rude
b22smith
I assume the water discharge on my engine is part of the exhaust port? I can't find any other tubes or hoses and that's where the water spits out. I'm new to this engine so just confirming this info since I can't find it in the service manual.<br /><br />(By the way, if you read my previous post "Smok'n", all the white smoke disappeared since I hooked on the muffs instead of using a 30-gallon trashcan full of water! Amazing.)
Chinewalker
Re: Tell-tale on '66, 6hp 'rude
Water exits your motor through the thumb-sized exhaust relief hole midway up the back of your motor leg. Should have a good, solid gush, like an un-aerated water faucet on medium....<br />- Scott
