'70 Mercury 1150, sn: 2840981<br /><br />Finally got my engine to start. Now another issue, maybe?<br /><br />When it first starts up, in a tank, the water started to flow, after a moment, from the tell tale hole. It was a good stream. But then just moments after that it became a sputter. The block was very hot to the touch also. Water pump has a brand new impeller.<br /><br />In reading here, it seems a few things I need to do are:<br /> run a wire, or weed eater line, through the tell tale hole to dislodge debris<br /> pull the exhaust manifold cover to visually check the water passages<br /> rebuild the entire water pump<br /><br />What else could it be?
