Temp gauge 2001 v6 looper
mr gibbs2
Just brought another boat it has a 2001 200 Hp Johnson looper on it with 200 hours and I want to know if I can put a temp gauge on the dash for my motor without running a new wire from the heads with a bolt on Senser . Is there any way to use the wires under the dash ( harness ) to pick up the temp . Also since the motor is not equipped with the systems check gauge ,has the horn in the bnical mount . Can one me installed plug and play ? I just always want to know the head temp and water pressure and low oil so I don't smoke the motor . I've had many loopers in the past and ran the. Wires from the motor to the dash with a gauge always knowing head temp . Thanks
