MightyEsquilax
- Joined
- Jul 15, 2012
- 32
Alright, I've got another topic I just can't seem to crack on my own. I have a 1996 7.4 Bravo 3. The old temperature sender was junk and wouldn't ohm out so I replaced it. While I was replacing the sender I also tested the function of the temp gauge by grounding the S pole to the G pole and as expected the gauge went full hot. I installed the new sender but now my temp gauge is reading way hotter than I think it normally should. It will creep from below 100 all the way to somewhere in the 190-200 range ALL THE TIME regardless of plane or idle speed. First, I know the boat isn't overheating. I used an IR therm and I have manifold temp of about 130-140 when she's all warmed up. I have good water flow through the system and no leaks. The elbow temperatures are about 105 degrees and 110 degrees (one is always supposed to be a little warmer than the other).
I took ohms readings at the sender and when the engine was all warmed up I got 121 ohms which according to the Mercruiser manual is supposed to be the sender reading at ~ 140 degrees...that tells me my sender is good and the sender is telling me about the same temp as my IR therm.
I admit the next step should probably be to buy some resistors or a pot and test the gauge at the resistance described in the merc manual. I had some 220 ohm resistors laying around so I hacked together a small test bench and I got readings on the gauge I thought were weird. At 220 ohms the gauge read about 130 degrees. At 430 ohms the gauge read just a "smidge" above 100 degrees. Anyone know what the gauge ohms readings really should be? Obviously the gauge needs to match the sender installed and I replaced my merc sender with a Sierra 18-5897 which is *supposed* to be a direct replacement for the merc 97257A.
I'd hate to spend $50+ on a new gauge (if I can find it) and have that not be the problem. Anyone know a convenient way to check the gauge or does everyone think my gauge is toast and I should just spend the $50? Did I miss something else obvious?? Thanks for any help!
