Temp. Gauge not working !988 Bayliner 2150 5.0 omc Cobra drive
Grundgie1
Temp gauge not working i replaced sending unit in block but no luck,replaced gauge still nothing allways reads 100 degres.Help please
Boatin Bob
Re: Temp. Gauge not working !988 Bayliner 2150 5.0 omc Cobra drive
Did it ever work? Do you know for sure if you have a thermostat installed?
Grundgie1
No it did not work,i just bought, i can tell water is circulating though,i can feel change in temp on hoses by thermostat when i run it, its cold then warm then gets cool again.could it be a bad ground?
hondon
Depending on the age of your unit ,you will likely have 2 temp senders. One for the warning horn and one for the guage.Did you replace the right one?Once you figure that out ,if you remove the sender wire from the sender and with the key on short it to ground , do'es the guage peg?If not ,since this is a new guage ,we have a bad sender wire.If so ,the guage and sender are not calibrated to each other.
cobra 3.0
I just bought an auto guage with sending unit from Walmart for $12.00. Works great.
Grundgie1
Thank you all, i ran new wire to gauge and it worked just fine thank you all for the help. Grundgie 1, God bless you ALLLLLLLLLLLLLL.
