imported_scott_m
- Joined
- Oct 24, 2004
- 139
Hi again iBoats and Happy Easter. I need some help thinking this through. I've got a 1990 Merc 135 2.5L V6 on a 1990 21 Sea Ray Laguna. I've had this boat about a year now, and think I either have a chronic overheating problem, or a gauge that is not reading right. About 6 months ago she started running warm, so not knowing the maintenance history on the boat I had the impeller changed. I also pulled the thermostats out of both heads (South FL). It seemed to be OK for a while, then about a month ago started getting hot again. So out of the water it came and in to the shop. This time, the shop (different, the boat was in GA when I had it done the first time) did a rebuild on the water pump as well as serviced lower unit. I got the boat back in the water 3 weeks ago. I ran it hard from the ramp back to the house and all was fine. Yesterday had the boat out idling around and it was fine, but then when I throttled up she shot up to 210 or so. Interestingly, last time it was overheating, I could put it in neutral and raise the RPM to 2500 or so to get it to cool down. That did not work yesterday, although just riding at idle speed would drop it down. Anyway, yesterday I felt the water coming out of the pee stream, and it was almost hot enough to burn your hand, although I would not say it was anywhere over say 150. Also, when I got back to the dock, I pulled the cowl and felt the heads and block and nothing seemed warmer than it should be. Also the pee stream is strong and there is water coming out of the ports. I'm wondering if I can put a DVM on the signal wire for the temp gauge to see if it is a problem with the gauge, sender, or wiring? Or is there any other way to determine flow through the motor? I have not checked the timing recently, but I think if the timing was so out of whack to make it run hot that it would not run well (performance is excellent right now).<br /><br />Sorry for the long post, but I'm out of ideas, and although I've done a lot to get ready for the spring king run (plugs, lower unit, water pump, carbs, decarbon the motor, etc.) here I sit with 71 degree sea temps, kingfish off shore and I'm tied to the dock. Look forward to your insight.<br /><br />Scott
