temp gauge
gunmaker
I have a 86 90hp Johnson v4. Is there anyway to put a water temp gauge on this motor?
ezeke
Re: temp gauge
They are actually engine temperature gauges, but yes. There are senders that clamp under the cylinder head bolt and hold the thermometer against the head. You can get them from your J/E dealer or from aftermarket suppliers. I use an OMC one on my 115. The sender has to match the gauge, so buy it as a kit if possible.<br /><br />I know that they sell the Teleflex ones here on Iboat and I bounced around for a minute trying to find the kit. I gave up, but look around, or maybe someone more patient will find it for you.<br /><br />Someone had a picture of the sender on another thread. Take a look: Click and See Second photo
Silvertip
Re: temp gauge
There are two types of temp gauges. The one described in the previous post is a cylinder head temp gauge. It measures the temp of the metal. Water temp gauges screw into the water jacket and monitor water temperature. Either type works, but the temperatures they record should not be confused.
ezeke
Re: temp gauge
Thought I had made that clear enough, if not, please accept my apologies. <br /><br />If someone can provide information that will assist in giving you a gauge that actually measures the water temperature, I will be impressed and so should you.
Silvertip
Re: temp gauge
Golly Ezeke -- no apologies necessary and I certainly didn't mean to contradict anything you posted. I thought I'd add a bit of clarification as not everyone understands this stuff. Water temp senders are variable resistors that present about 30 - 40 ohms of resistance at 220 degrees and about 240 ohms at 60 degrees. Senders need to match the gauge but they do indeed measure water temperature. The down side of a water temp gauge is if the water pump is not pumping, there is no water and hence no temp reading or a very incorrect one. Some gauges are calibrated in degrees while newer ones are calibrated Cold-Hot. Cylinder head temp senders are thermocouples. Either type is best used in conjunction with a water pressure gauge. Failure to pay attention to either one or to understand whats happening when readings change can be costly.
BoatBuoy
Re: temp gauge
Originally posted by ezeke:<br /> If someone can provide information that will assist in giving you a gauge that actually measures the water temperature, I will be impressed and so should you.
Maybe I misunderstood, but here's several of them: <br /><br />teleflexmarine.com/cgi-bin/frameset2.cgi?site=gauges&type=us&link2=1050
gunmaker
Re: temp gauge
Thanks guys, i'll check around now that i know for sure there are some.
