i have a 2001 mercury 250 efi. i normally run at about 4800 to 5000 rpm's at about 3/4 throttle and burn about 22 gals an hour. the other day at 3/4 throttle i was barely hitting 4000 rpm's and was burning 30 gals an hour. right as i was reaching port i started running normal again. i replaced my plugs but they did not seem completely burnt just a little black. also one was very loose and was leaking fuel from that cylinder. motor seems to be running good now. could my plugs have been the trouble or do you think this could be the begining of the onset of an intermitting problem?
