temp sending unit
joleda
I have to replace the sending unit on my Volvo AQ225. Is there a difference between an auto unit and a marine unit? I see prices ranging from $10 to $30, but they all look the same.
Thanx,
Dave
Moody Blue
Re: temp sending unit
Marine/auto are the same. You need to match the sender to the gauge. Senders come in different resistance values. Using the wrong sender with a specific gauge will result in a wrong reading. If you can pull the original sender it MAY have the resistance stamped on it somewhere. I think they are somewhere around 220 ohms.
The other thing to be aware of is the thread size where it screws into the engine. Will be available in 1/8" NPT, 1/4" NPT and 3/8" NPT.
