victoryinerie
- Joined
- Jun 13, 2010
- 62
1998 Merc 5.7
Bravo III
I have other posts on similar subject but I have more information since I took the boat out tonight to see what the acutal temperature is in the water vs. under the muffs. Again, sender is good, guage is good, thermostat is good.
With the thermostat in, boat temperature while running hit about 100, little less when I shut off the engine and turned the key to on the on position (engine not running) the guage would read 160 and cooled down slowly.
With the thermostat out, boat temperature while running hit about 100, little less when I shut off the engine and turned the key to on the on position (engine not running) the guage would read 110 and cooled down slowly.
The previous owner said he replaced the impeller and that he found pieces of it when he changed it out. Could there be other piece lodged somewhere that would cause what I am seeing?? I checked out the thermostat housing and did not see anything. Where should I be looking? Should I be looking around the recirclating pump??
I also checked the gaskets on the riser/manifold and verifed that there were only two openings vs. gaskets with 4 openings.
Any suggestion on where to start looking??
Bravo III
