dirtmover
- Joined
- Sep 24, 2007
- 9
Went to take the kids out today and noticed that when I started the boat the temperature gauge was pegged at max. Now I wasn't observant enough to notice if it started like this or rose during the first 5 minutes of running. As soon as I noticed I panicked and turned the ignition off. Of course after a few moments of thought I realised that >250F was an impossibility.
I restarted it an immediately the gauge pegged at max again. Brought it out of the water, put some muffs on and restarted it. The water outlet was hot but not overso. Still pegging at max. Left it 30 minutes or so to cool. This time when I started it the water was cold. Thermostat obviously OK. Checked out the wiring from sender to gauge and pulled connections to check for corrosion. Started it again and still pegging at max. This time, with the engine still running, I disconnected the sender. The gauge dropped back to zero but when I reconnected the gauge went up to where I expected (about 130F). Sopped it, restarted it multiple times and everything is OK.
Any ideas what might be wrong here?
