Temperature rising at idle
jsmigielski
I have an 86' sea ray and the temperature rises at idle and slow speeds. I can get the temperature to go down by accelerating and it holds steady at cruising speed. Any suggestions on where to start?
Grand Larsony
Re: Temperature rising at idle
Replace water impeller AND housing, check for any obstructions on intake (holes on side of IO unit), be sure not outflow obstructions (flapper in Y pipe), no kinked coolant hoses (especially the one from outdrive to thermostat housing).
When was service last done -- especially the impeller?
Grand Larsony
Inspect and clean thermostat housing, replace t-stat while there.
Brentathon
Which engine do you have?
I had a slow speed over heat years ago, and it was related to the highly corroded T-stat housing, that didn't allow the little white plastic "check balls" to properly seat. But that was on my raw water cooled 1990 5.7.
The check balls provide some back pressure, which keeps the coolant circuit topped-off, as well as helps to equalize the water that's divided to each of the exhaust elbows.
If they don't seat well, cold water from drive can exit to the elbows, bypassing the block.
greg82255
The impeller is the first place to look in an overheating situation. Pull the lower and replace the impeller, and if you don't know when it was last done, might as well do the housing too. Make sure you use OEM parts. They're a little more expensive but most of the experts on these forums say they are worth it.
