enginepower
- Joined
- Jul 5, 2014
- 260
1995 90hp 3cyl serial 0g174918. I removed the terminal block thinking it is a rectifier and performed a diode check on it. I am reading open circuit both directions of all terminals. The setup also has a small voltage regulator/rectifier and charging system working ok but tach sticks at certain rpm's and doesn't move until a big increase/decrease in rpm's occur or if I hit the trim switch. The back side of the terminal block has that epoxy sealant stuff used to encase electronic parts of this nature. Anybody familiar with this setup and know if the terminal block is an actual rectifier?
