I had a 12 volt motor guide trolling motor, and bought a 24 volt Minn Kota Terrova i-pilot. I have 2 batteries for trolling and I used a short jumper cable, and connected one end to minus post on battery #1 and the other end was connected to the plus post on battery #2 then connected the red wire to the plus post on battery #1 and the black wire to the minus post on battery # 2 now if I'm right, this should send 24 volts to the front of my boat.
up front I have a marinco brand receptacle, it has 3 holes for wires, it is a 12/24 volt DC I put the black wire in the minus hole, and the red wire in the 24 volt hole. and left the 12v hole empty. tried it and had no power. batteries are full charged. now on the back of the female receptacle it has 4 spots for wires to connect to it. A plus and A minus B plus and B minus I changed the wires from the two A's and connected them to the two B's still no power. what am I doing wrong, any help from some one that knows what I need to do here would sure make me thankful. and thanks in advance for any help.
