test overheat alarm
my1stboat1
How do you test to see if the over heat alarm is working on your 85 hp force outboard...
I bought a new buzzer but want to make sure it actually works
huskerdaninva
Re: test overheat alarm
You need to look at/find the overheat sensor on the cylinder head, remove the wire, ground it to say the engine block or what have you, and with the ignition energized the buzzer/horn etc. should sound. Hope this makes sense...
jerryjerry05
Piece of wire.Ground it on a bare piece of metal.Key on.Touch the ORANGE lead on the terminal with the other end of the wire.It should activate the buzzer.
Fill out the profile.You might be close to someone who can help(or you might be close enough to take me fishing:) :) Jerry
my1stboat1
Thanks guys... hey jerry ill fill out the profile now... But hey your welcome to come fishing anytime. I see your from Florida and im up here in Jersey... But hey let us know how the fishings going for you guys down south...
