In a previous post (i couldn't find) I mentioned that my motor was throwing rooster tails. Someone suggested that I raise my motor so that the cavitation plate would be even with the bottom of the hull,(which was about 3 inches below hull line) so I did. I did a test run this weekend and noticed a couple changes. Here they are: 1) water pressure dropped considerably while @ WOT, but returned to normal at idle. 2)RPMs did increase, but not considerably (1-200).3)Rooster tail did go away. I would guess that the water pressure would be the most important aspect, so should I lower my engine back down? It did not lose water pressure @WOT before I raised it.
