How much support the engine need for a test run in the garage to be safe?
(Does it need to be bolted down to a pallet ore something)
Any easy trick for start and stop, wiring switch?
Minimum to not damage anything, and perform a safe stop of the engine.
I would just use a multimeter for oil pressure and cooling temp.
What is the violet wire in to the merc carb?
And how should this be wired for test start/running)
The starter was disabled when I got the engine, is the solenoid "m" terminal in use, and what color on this wire?
And what color on the solenoid "s" terminal.
Hard to read color on the old manual, and better safe than sorry
