Re: Test run on 1972 evinrude 125 w/o controls
you have 2 wires coming from the lower unit, green and blue. power to neither means lower unit is in forward, boat wont start in forward! power to one wire is neutral and both is reverse. i have 1970 85 hp v4, i know your woes... i ran my boat without proper controls perfectly fine.<br />i used a 3 way push / pull type switch for the shifting, since my 3 button shifter that came with it was badly destroyed... pushed in all the way, it cut off all voltage so there fore it was on forward gear.. pulled out to selector number 1 was voltage to 1 wire, therefore nuetral, and pulled out all the way, selector number 2 was voltage on both wires, therefore it was in reverse. and as for starting, i used a single red, push button style switch, momentary on for starting purposes, wired into the starter selonoid at the post with the two red wires.... and to kill it, i wired in a simple on/ off switch to the purple wire going to the big ugly wire bank, and when that switch was off, motor died since voltage was cut out of ignition... now all of these colors of wires are from memeory seeing how its late and all, but youll get the jist of it !
<br /> with this set up , it technically eliminates the need for a wire harnes also, seeing as to how it also eliminates a key.. you can add a push style switch later if you want to use the electric choke... its all up to you....
