dingbat
- Joined
- Nov 20, 2001
- 16,420
All of these statements are either true or false, albeit some are not so clear cut.
Let?s see how well you do
Action:
1. An extra fast rod will generally only bend in the top fifth of the rod and as you move down the scale, more of the rod will bend, where at the bottom of the scale you?ll find that a slow action rod will start to bend all the way down in the lower third of the rod.
2. You want a light action rod so it bends easier and further down the rod length to produce enough energy for a good distance cast.
3. The idea that a fast action blank only flexes in the upper 1/3rd is inaccurate. Even a fast action blank will flex deeply into the butt area if you apply more and more load to it.
Power:
1. It is important to keep the line weight within the constraints of the rating on the rod
2. Line weight designations refer to mono fishing line.
3. The rod will ?dead lift ? the stated (line) weight at angles less than 45 degrees from parallel
Graphite:
1. IM8 graphite rod is better than an IM7 graphite rod. Generally what better means is that the actual material used to make the rod is better. Higher ratings mean better material
2. Higher modulus increases the chance of breakage
Guides:
1. The makeup of the ceramic runs the spectrum from silicon carbide being the best to Alconite, hardloy and aluminum oxide. The difference between these different materials is how smooth the ceramic is.
2. A higher ?grade? of guide the easier your line goes out of your guides and the easier it is to cast
Action:
Power:
Graphite:
Guides:
