I purchased a used 85 horse Johnson (j85ttleo). I was only able to run it once before putting away for winter. While doing some work on it I noticed that a couple wires comming from the rectifier are disconnected and taped off. I have the Factory manual, but all I found in there was a test while engine is running. I wont be able to start the engine til spring. Are there any tests I can do on it without starting it? Thanks
