Hopefully I am posting this in the correct spot, so I apologize if its not.
Is there is a simple test I can do on the charging system to see if its working properly? I have a 1998 Force 120 HP OB. I just put in two batteries with a switch (1/2/Both/All). One is a deep cycle and the other is a starting battery. I have the deep cycle running just the radio, horn and bilge pump (if its ever used) and then the starting is of course for the engine. I started the engine up and the starting battery runs about 12.71 V while engine is idling. I have heard that if the charging system is functioning correctly that it would read more in the 13.5 V range. Is there truth to that at all?
