ESGWheel
- Joined
- Aug 29, 2015
- 534
To test if there is a DC based ground leak is straightforward. Three steps and only requires a good multimeter (MM) capable of both resistance and DC current.
Note: this process assumes no interconnected AC shore power or solar panels or chargers. If they exist, all need to be completely removed from the DC side.
1st - Validating there is an issue:
1) Turn off all equipment
2) Disconnect the positive side of the battery.
3) Leave the main battery isolation switch turned “ON”
4) Set the meter to VDC mode, range appropriate for your battery (i.e., 12 or 24VDC)
5) Connect the meter between the positive terminal and the disconnected positive cable
The meter should give no reading. This means there is no path for current (i.e., a ground leak) and there is a completely open circuit as expected. If it reads XX volts for your XX VDC system, one of two things is happening:
1) Some connected equipment is turned on. This could a power feed to a stereo for the radio's memory, or a hard-wired detector or some other device like lights or the bulge pump in the “on” condition.
2) After disconnecting all the "hard-wired" equipment / turning off any other gear and still get a reading, then most likely have a ground leak in the boat's DC system.
2nd - Ground leak check:
1) Set the MM in Ohm mode and set it to the lowest range (x1).
2) Connect the leads of the MM to the disconnected positive lead and the negative terminal of the battery.
The meter is now reading the resistance of any circuit to ground that exists in the boat's wiring. The reading on the Ohm meter display will help identify the cause of the leak.
0-10 Ohms means it is most likely a piece of equipment still left on
10-1k Ohms is a low-drain piece of equipment left on, or a serious ground leak
1k-10k Ohms is a minor leak
10k+ Ohms is an insignificant leak
3rd - Determine how big of a leak:
The ammeter function of the MM can tell what the current leakage is. If the MM can read up to 10ADC, then it can be used it to measure amperage for leaks down to about 1.3 Ohms resistance on a 12 VDC system, or 2.6 Ohms for a 24 VDC. (Ohms Law: Current = Volts/Resistance > so 12VDC / 1.3 Ohms = 9.2ADC and same for 24VDC at 2.6 Ohms). Using Ohms law and the value of your MM’s DC Amps determines how low the resistance can be. Most MM’s ADC are protected by a fuse but still be cautious doing this. To see how big the leak is:
1) Set the MM to Amps DC (may require using different MM probe inputs)
2) Connect the probes to the positive battery post and the disconnected positive cable.
The meter is now reading the current flow of any circuit to ground that exists in the boat’s wiring. The readings can be characterized as:
<1mA - insignificant leakage
1-10mA - minor leakage
10mA-1A - major leak or some equipment left on
>1A - Usually some equipment left on.
While I have used the above process in my automotive days, the logical outline, and values for determining leakage characterization came from another post of about 10 years ago that I ran across.
For those with expertise in this area, please provide any corrections or comments to help all of us with these sorts of troublesome issues.
