phoenixgold2100
- Joined
- Feb 3, 2013
- 154
I have read online when testing the rectifier if you connect ohm meter to ground and touch the rectifier leads you should only get a reading one way...my problem is I only seem to get a reading of 10.2 from the gray tach wire. I touch the leads to the yellow plug either side, and nothing happens also from ground to the red wire nothing. Should I be getting a reading on the plug? and from the red wire? Is my rectifier toast? thanks guy. I'm lost here. Also it looks like someone put silicone under the rectifier would doing this mess with it grounding at all? I'm sure its a gasket just checking thanks again.
