brnschoneck
- Joined
- Feb 22, 2013
- 337
motor is a 65 65hp merc...I am only pushing 12.45 volts when running? ??I am thinking it isn't charging rght ....what ohm should staor read testing two yellow wires seloc manual doesn't say for this motor ...It has a old recticier wich I think is bad but numbers are wore off so I can't tell terminals is what just the red wire n two yellows what's the best easiest test to do ...serial number is 180456 ???any suggestions is appreciated...I know some of the motors idon't charge batt ...anyone know if that's the case ???
