a while ago the earth wire on 1999 200 efi trim sender unit corroded through.i fixed this worked for awhile. when this happened the trim guauge pointed vertical off the scale.this has happened again.i have cheched and redone earth connection with no difference. how can i test to see if sender unit is at fault.
