Testing Y pipe for leaks- no outdrive installed
bashr52
I'm getting ready to get my boat out of winter storage this weekend, and before I put the drive back on, I want to verify the flaps are still in the exhaust, and check the Y-pipe for leaks. I was having an issue last season with water leaking into the bilge, and I want to verify if the Y-pipe is leaking or not, and may be the source of the water. I will be replacing the bellows, gimbal bearing, shift cable, etc at the same time. Should I plug the end of the pipe somehow to see what happens when the water sits in the pipe, vs just running through?
Brentathon
What type of drive?
Don't discount the upper swivel shaft seal....usually is a small trickle, that works its way down to the look like it's coming from the bottom of the Y-pipe....especially if your drive sits low in the water (i.e. stern heavy boats). JR Marine makes a 17-4PH (stainless) swivel shaft, which is awesome.
if you have a leak, it will be where the flaps fell down and the shaft wore thru the y-pipe. you should see the hole.
you can try to fill the y-pipe and look for leaks
then again, with the motor out you should be able to see the flaps
bashr52
Alpha 1 gen 2. Engine is in, drive is just off for a reseal and bellows/gimbal bearing change. I could hear water trickling into the bilge after I pumped it out, never could see it which leads me to believe it's down low under the engine, in the area of the Y pipe
Bt Doctur
If you didnt fine water in the main bellow you can eliminate that part , next is shift cable bellow, easy enough to pull and see cracks or tears.
Y pipe ,you should be able to spray into the exaust and see it drip inside the boat, that would be a bad Y pipe
bashr52
I did find water and gear oil in the drive bellows when I pulled it. The driveshaft seal on the outdrive was bad and leaking gear fluid, which is why I pulled it before storage. Perfect opportunity to change the water pump too! I have a new shift cable bellow as well which will go in, but I just bought the boat late last season so pulling the exhaust to check the flaps and pipe at the same time.
Bt Doctur
Then I would go with a main bellow leak or the mounting gasket was damaged or the thick rubber ring was not glued in place and was dislodged
