Re: Thanks Tail_gunner Uphostery on seat corners
Imagination, what you see as blue is 1 inch foam, took a electric knife and round the foam and laid it down on a full length. Then i took 1/2 inch and again rounded it, from there i took 1/2 board and cut the white pattern you see streched the vinyl (heated). So its a two peice const. Hmm ok 1 long frame _________________ made a form of foam what you see as blue. then what you see as white _______ sits on top of that long frame or base. Only its 1/2 inch foam stapled to a 1/2 inch frame. Then i just bolted the smaller white frame to the larger blue. Notice the wood on the ends, thats where the laying down of the white template takes place.<br />--------------------------------------------------------------------------------
