You guys are great! I was winterizing my boat yesterday, and while draining the block I remembered reading here that I should poke around all the drains to make sure there isn't any garbage plugging up anything. Well, wouldn't you know it, there certainly was plenty holding back the water! Thanks to this forum I knew enough to free up those passages!
So I was wondering... There are caps on the back ends of both exhaust manifolds that I took off to drain the water. I poked around with a small screwdriver and some gritty garbage came out. I tried sticking my little finger in there just to check out the passage, and it seemed to get kind of narrow. So I wonder how much stuff could be in there clogging everything up. Is this something that should (can) be cleaned out? There was a bunch of stuff at the engine block as well.
