Thank you for all your help with the continuous warning horn, it turned out to be the sensor on the oil injection pump. so now I change the pump or I put the conversion kit on and hand mix the gas and oil. Thanks again
Those pumps are pretty robust, doubt its bad.....Problem is typically the gear that drives the pump shot. I sense a conversion and mixing in your future.
