Re: the 1st oner may have used auto oil
I'll try to put my prior pump-jockey skills to work here.<br /><br />The key for using 30WT in 2-strokes, is that is needs to be NON-DETERGENT, unlike most multi-grade engine oils are today.<br /><br />I believe detergents had too good of cleaning effect when burned, thus possibly increasing wear that the oil was supposed to reduce.<br /><br />In the 50's , there was not much (if any) detergent oils available, so it was probably not referred to much, concerning outboard premix.<br /><br />I would suggest filling the tank with good premix and go boating. If it has not fried in 16 years, it is probably fine.
