The best way to treat a Merc!
kenmyfam
Re: The best way to treat a Merc!
Oh now that sucks !!!!
How much rain did you get ?????
samo_ott
Apparently more than most folks thought. I did however bail out my boats between storms. Luckily.
Home Cookin'
looks like the head is out of the water, barely, so if they can get it up CAREFULLY it may be OK. it's tricky when they are swamped. BTDT
Texasmark
Agree with cookin. Nothing hurt that I can see. The only problem in fresh water is ingestion into the carburetor or water backing up into the exhaust manifold. The way it's sitting I see nether as a problem. I know the boat is small, probably doesn't even have a battery, but that is why they make self baling switches for/to supplement balers.
Mark
Jlawsen
They also make cover poles that go inside to hold the cover up and let the rain run off the sides. A cutoff broom stick will do the trick. If the cover is lose it's not 100% effective but, it can buy you some time.
