Re: the blue impeller
Professional BoatBuilder June/July 1998<br /><br />LONG-LASTING IMPELLERS, EASILY REPLACED<br /><br />By NIGEL CALDER, Contributing Editor<br /><br />Overheating is probably the most common mechanical problem on a marine engine. Most often, it's caused by a loss of raw-water flow that occurs when the raw-water pump impeller fails. Rubber impellers on raw water pumps are typically made of neoprene, which is susceptible to damage from being run dry, and from water contaminated by hydrocarbons, effluent, and other chemicals. Depending on pump and impeller accessibility, replacement can be anything from a speedy process (a few minutes), to a time-consuming exercise in contortionism. The solution to these complaints associated with raw-water pumps is twofold: install impellers that are more tolerant of the kind of abuse experienced in real-life service; and simplify the replacement procedure for an impeller if it does fail.<br /><br />Long-Life Impellers<br /><br />For years, Globe has been manufacturing long-life replacement impellers for most popular marine raw-water pumps. These impellers are made from advanced elastomers, which not only have a greater resistance to chemical degradation than normal impellers, but can also withstand being run dry for 15 minutes. If the engine suffers a loss of its raw-water cooling supply, a Globe impeller unlike a regular impeller will keep on running long enough for the engine-overheat alarm to sound before the impeller is destroyed. In normal service conditions, the Globe impellers have a longer life expectancy, particularly in sandy and silty water than most standard impellers. When they do fail, they tend to crumble rather than having the vanes break off. The small pieces pass through the cooling system instead of plugging the tubing and heat exchanger. Globe's blue impellers are for regular raw-water service (the red, for pumping diesel), and are competitively priced.
