The Capacity Sign...
HollaGeo
I have a 1975 15 foot Checkmate. However, I am missing the yellow sign that tells the maximum occupancy, engine, etc. Is this something that is against the law not to have???
NYBo
Re: The Capacity Sign...
Unless Jersey requires it, no. It's a federal requirement for the manufacturer to put on on the boat but not for you to have one.
foodfisher
Kinda like the do not remove tag on your matress. But I would't exceed the max's on the tag for safety and ins. purposes.edit: Thinking a bit more, The CG may require it if you're boating in their waters.
Talk to Mike Combs at Checkmate 419-562-3881. If it's at all possible to get a replacement capacity plate he'll hook you up.
What kind of Checkmate do you have, an MX-15 maybe?
Thalasso
Under the U.S. Coast Guard Federal Boat Safety Act of 1971, boats less than 20 feet powered with an inboard, outboard, or stern drive engine manufactured after November 1, 1972, must display a capacity plate defining the safe load limits. This plate must be mounted where you can see it when preparing to get underway. Sailboats, canoes, kayaks and inflatable boats are exempt from this standard states do have statutes prohibiting the carriage of people and gear in excess of the stated capacity, or the installation of a motor that exceeds the recommended horse power limit. Also, you may void your insurance policy if you are found to have exceeded the limits stated on your capacity plate.
Do what metriccresentwrench suggests
