Re: the enrichment valve??
Dunno what you are talking about. The only enrichment valve I know of is a valve that is operated by the key (used for starting). Upon depressing the key, a solenoid in the engine opens and sends additional fuel to the carburetors so that you have a very rich mixture when you hit the starter.....like a choke does, but it restricts air and this adds fuel.<br /><br />You can take the cowl off and see the valve (the "other" hoses connected to the carbs come from it) and upon initializing it from the remote control, you can hear (the solenoid in) it energize. If you are in doubt as to whether or not it works, just pull the outlet hose off (the solenoid output), turn the key on and push on it. If fuel squirts out it is working. <br /><br />Mark
