dOb
- Joined
- Jun 14, 2010
- 244
Thanks for all of the great information on this site. And thanks to those that have helped me this far.
This is my first boat. It seems that every time I fix something, I discover something else that needs fixing. I have so many questions now that I figured it was time to start a thread. Im going to need a lot of help with this one. Heres a brief history to let you know where I am.
I bought the boat for next to nothing. The rollers had given out, and the boat was sitting on the roller mounts. It left a few small gouges.
The seller told me that with a few minor repairs, Id be the water in no time. I replaced the rollers and got the boat sitting good on the trailer. When I was replacing the bilge pump, I realized that I could dig the old transom out with my fingers. The deck felt solid, and when I removed the old transom, the stringers seemed solid. I hit them with a hammer, and when I jammed a screw driver into the wood, it grabbed on pretty well. So I figured I was OK. Thinking the stringers and deck were fine, I just cut the splashwell off to get to the transom.
I took my time and replaced the transom (with help from this forum). I even painted it.
No all that is left is to grind out the gouges, do some patch work, and Ill be on my way. Right? Wrong!
There are three gouges on the keel. When I ground out the first two, I could see the stringers (I didnt realize the gouges were that deep). I checked the stringers again. The wood was hard, but it was wet. Now Im getting concerned. On the third gouge, towards the bow, there was no wood. But there was foam. I could sink a screw driver in, and feel the squeak of wet foam. So I cut a hole in the deck, and stuck the screw driver in, and again, squeaky wet foam. Im pretty sure the boat is filled with heavy wet foam. That would explain why I cant lift the front of the trailer.
So here I am. Too far in to stop now. Ive made some mistakes, but Im enjoying the process. Im going to pull the rest of the cap, replace the stringers, foam and deck. And then see what else this boat has in store for me. I should point out, Im not looking for a pretty boat, but I do want a safe boat.
And heres the first question -
I decided to remove the windshield before I pop the cap off to lessen the weight. Im going to have to hang it from the rafters in my garage. I discovered that all of the windshield bolts are rusted out.
I tried to remove one of them, and it snapped of.
If I snap off all of the bolts to get the windshield off, will there be a way of replacing them later? Ive searched but I cant find out how these things are constructed. Or, should I just leave well enough alone and hang the cap with the windshield in place?
Thanks.
Thanks.
