johnnynegaunee
- Joined
- Jul 24, 2007
- 69
I have an R drive '72 3.0L Merc Starcraft. I am replacing the engine with one from a donor boat '74 that hit a rock (engine with low hrs.). The front plywood that the front motor mount rested against was rotten so I replaced it with oak. I realigned the the motor and now that I am trying to remount the outdrive I find that the last 3/4 inch is very sticky and I will need to take a wood block and modest persuasion from a hammer to it to get it all the way on. Is this normal? There are 2 rubber O rings on the shaft about where it wants to stick. Is this the cause?
When I removed the outdrive it was sticking for this same distance, but I thought this was from the sag in the rotten plywood affecting the alignment.
Thanks for any tips or info. you can give me.
