My mechanic told me that a vro unit should be replaced every 10 years. Here is my history. 1995 60 hp evinrude vro, bought it used in 2003 with 150 -151 psi in every cylinder., burned maybe 6 tanks of gas though the engine at 65 liters each to present. ( no more than 90 gallons of gas). I know that age does have a factor on the decay so is this true ? Should I invest in the purchase of a new vro and install it, or keep on going. I have checked for bad fuel lines and connections , am considering changing carb and oil lines as well all fuel lines to motor. I would rather look ahead than say I should have. All work has been done to motor as carbs rebuilt and cleaned in 2008, impeller changed in 2007, and engine religiously fogged, full fuel stabilizer , bottom end oil change every year. PS> I do not have a problem with the VRO.
Thank-you in advance. Greg
