The perfect recipe for the perfect homemade french fries
waterinthefuel
I've been chasing the right combination of temp, length of time for cooking and then the ice bucket for over a year, and a little while ago, I finally nailed it. Now I want to share it.
For this recipe, you'll need a french fry cutter that cuts the fries into 1/4" cube sized slices. A common french fry cutter will do this. The other thing you will need, and this is the secret......a bucket or container of ice water, literally with ice cubes floating in it. Have this ready for the next step.
The first thing you need is to cut the potato into fry shaped slices. If the potato won't fit in the french fry cutter, cut it in half first. If you do, place the UNCUT end of the potato against the cutting blades before proceeding to cut the fries. If you don't, it will be almost impossible to cut.
After you have cut the fries, you'll need to dry them well. Use a paper towel or even regular towel for this. (Don't worry about germs, dropping them into hot grease sterilizes everything instantly) After you dry them, heat your oil to 375 degrees. Place the fries into the grease for 2 and a half minutes. At 2 and a half minutes, immediately remove the fries from the grease and place them into the ice water. This stops them from cooking. While the fries sit in the ice water, heat the grease to 425. After 10 minutes or so of them sitting in the ice water, take them out and dry them again. Failure to dry them will result in excessive popping and splashing of the hot grease when the cold fries are reintroduced. When you place the fries back into the 425 degree oil, time it for 1 minute, 30 seconds. At that time, immediately remove the fries from the grease and place them onto a plate with a paper towel on it to absorb excess grease. I personally like dry fries so I use another paper towel to dry them even more. At this point you can eat them plain, you can add salt or you can add french fry seasoning.
The result will be a fry that is crispy on the outside, yet fluffy on the inside and will be a beautiful golden brown. While it's a lot of work and trouble and does make a mess, the end result is a huge pile of fries that literally cost about 1 dollar. It would cost about 7-8 dollars at McDonalds to buy the same amount of fries that I can make for about a buck. And I can season them the way I want to. I use the large potatoes from the grocery store, leaving the skin on. You can skin the potato first if you choose. That's a personal choice. To determine oil temp, I used an infrared digital thermometer, so my temps are accurate to within +/- like 1 degree. This is a much more accurate way of determining oil temp than using the knob with the preset numbers on fry daddys and such. And is safer than sticking something down into the oil like a temp probe. The infrared thermometer keeps your hands safely away from the grease.
I always did all of my frying outdoors but my frying pans and such couldn't get the oil above 375 so I fried these on my stove. Just remember, between batches, to turn the stove off if you choose to do this inside. (Just put the fan on above the stove to suck out all the smell. I was worried about it smelling bad in here after I finished, but it doesn't.) I say that because between my first batch and second batch today, while I was chowing down, I forgot the light on. I come back and the grease is smoking like crazy. I checked the temp, 561 degrees!!! Yikes! I almost had me a grease fire.
Just be careful and you can have a blast making your own french fries. Kids love french fries, so they can participate in helping too. Just leave the grease part up to the grown ups, but they can surely take the fries out of the ice water and dry them and such for you. Kids love to eat things they just cooked, and french fries aren't something you usually cook at home so they'll think that's pretty neat.
Dip 'em in ketchup if you wish and most importantly......Enjoy!
rivermouse
Re: The perfect recipe for the perfect homemade french fries
You seem to know your way around the kitchen pretty well.
jigngrub
Franch fries are too fattening, gimme a baked potato with butter, sour cream, and bacon bits instead!
waterinthefuel
I use corn oil, 0 trans fat. Its actually considered heart healthy.
bassman284
I can only sit here in awe.
colbyt
I can't decide if that is your tongue or chew of Baccy in the side of your mouth. :)
The simple truth is that a fried potato in unsaturated fat probably absorbs less fat than a baked slathered in butter. A potato to which I would add at least 3 TBS of butter make really crisp home fries in 2 TBS or less. Butter and corn oil each contain the same amount of fat per TBS.
@waterinthefuel. Nice share but it sure sounds like a lot of work that way.
ngt
Ask someone who really knows about GMO's in food in the US and see how healthy anything made with corn actually is.
Oh, and your fries sound great :D
Fishing Dude too
Ok here is why the ice water works. It changes the starch of the potato to sugar making them crisp. Putting them in freezer for a short time works just as well.
waterinthefuel
Well, you're wrong but for the right reason.
I dunk them in ice water after frying them briefly. Others have said to put them in ice water for a long period of time BEFORE ever frying them. I didn't find this worked as well as my method. What you ended up with was either overcooked fries or fries crispy on the outside and soggy on the inside. Others might have been successful in this, but for me, it didn't work.
The ice water I put them in only ceases them from cooking. You might have read to put them in ice water, but it was for HOURS, not minutes. Nothing happens to them in ice water in minutes regarding changing starch to sugar. It takes far longer than 10 minutes. Putting them in the freezer won't shock cool them as effectively as ice water will. 2.5 minutes makes the fries fluffy on the inside but not yet done. Throwing them in at 425 for 1.5 minutes makes the outside crispy, but not in long enough to change the texture of the inside of the fry. Basically, I used the ice water, but completely differently than what others have recommended.
And yes, it is a lot of work, but you don't do it for one batch. You'd do like 5 potatoes at once and end up with enough fries to feed a small army. That makes it worth the trouble. Because once you have everything out, you're like a french fry assembly line.
I guess you can stick them in the freezer, but your results may vary.
staydry
Why didn't you tell me this two weeks ago!!! We struggled unmercifully trying to cut a potato...thought the blades were installed backwards.....
Appreciate your recipe and will definitely give it a shot.....
lncoop
LOL. Consider the source boys. In Alabamy crappie is considered a vegetable.:boink:
Tim Frank
Ummmm....no, it doesn't. :eek::facepalm:
The reason that you ice potatoes that you are going to fry is that it lowers the core temp so that you get a nice crisp skin without ruining the innards.
Works for fried fish as well. :D
Bamaman1
I believe in keeping my life simple. I don't over think cooking staple items.
1. Heat the vegetable oil to 350 degrees. (Much higher and it'll smoke, break down and be potentially a fire hazard.)
2. Peel the potatoes. Cut'em up into the proper size/shape.
3. Immerse in hot oil and cook until they're brown.
4. Remove and drain on paper towels--on platter.
5. Sprinkle with salt.
Enjoy!
waterinthefuel
Enjoy!
Did you even read my OP? Corn oil doesn't reach flash point until 650-700 degrees, 425 is completely safe. I had mine up to 561, and other than a little bit of smoke, it was fine. It only got that high because I forgot the light on. Never fry at 561 degrees! LOL
I did what you specified the first time I made fries; you're going to wind up with soggy, limp french fries. The extra steps are necessary to get the right texture. I even specified that my outdoor skillet couldn't get the grease hot enough. It topped out at 350-375, depending on the fry daddy used. You need 425 to shock the fries into quickly getting crisp on the outside but NOT cooking any further on the inside.
Think about it, that's what McDonalds does, really. They pre-fry them before shipping, and then they freeze them and ship them out to the stores. The stores take them and fry them in very hot grease for a very short period of time, which is why your fries are ready so quickly. They are shipped to the stores with step 1 and 2 already being done. They just have to take the frozen fries and dump them into the hot grease one more time to crisp up the outside.
If you do not cool the fries the starch will make them limp and gooey.
smclear
The process you describe is called "blanching" and has been used for quite some time. I was taught this technique at a restaurant I worked at back in the late seventies. It is absolutely the best way to make a fry.
Tim Frank
One addition to the OP's recipe that would REALLY be the perfect fry is to cit your spuds with a crinkle cutter.
The extra surface area takes them to another quantum level.
waterinthefuel
I'd like to add that you might want to add a few degrees to your oil temp if you aren't using a deep fryer. I just made more fries and my oil cooled for 425 to 300 and I wound up with soggy fries. So for the 375, if you are frying in a shallow pan, crank it to 425. For the 425, crank it to 475. That way the oil cools down to around the temp you want when you drop the fries in.
redneck joe
cast iron for your cooking vessel? That helps a lot, plus 'cranking it up to 11' for a few minutes just after you drop.
gm280
Of all the subjects one could possible even imagining to read on a boating forum, this sounds the tastiest!
Mud Puppy
I hope no one takes offense to this and please don't consider this a "Bump" by any means.
The fries sound wonderful, but so does the baked potato too! I am all for the salt, the butter, the sour cream and the bacon bits, but I was wondering if you could add a pound or two of bacon to either one of these and still have the same outcome?
I LOVE BACON!
