Re: the procedure for a motor after 5 months of winter storage
My feeling are if you Winterized it properly, there will be very little to do in the spring. If you have VRO, I would clean out the Tank to be sure there is no moisture in it and refill. Make sure the prop is in good condition. Check under the Cowl to make sure there were no critters in there and to just give it a once over. Change Fuel/Water filter if you did'nt in the fall. Check steering, Throttle and Fuel linkage for proper operation before hitting the Water. I'm sure there are other things that folks do, but that's all I can think of right now. I'm sure when the time comes, I'll think of more.
