So, yes, I get it... the proper propeller question is probably the most asked question on any boat forum. But... I'm still going to ask it. What good is a boat forum without a virtual cornucopia of screw threads? Everyone loves to ad their 2? (I've got a mac, so making the "cents" sign is as easy as pressing option + 2) to the prop threads.
First, my current boat specs:
And the current Performance:
The boat came with a Mercury 21 pitch aluminum 3 blade prop installed. The stainless steel prop came as a spare and was a bit chewed up. I had it reconditioned and tried it on the boat. Performance seemed damn near identical, but at slightly lower RPMS (engine speed probably dropped by 200 rpm with the ss prop). It may have jumped out of the water just slightly quicker (perhaps more noticeable when heavily loaded). The difference certainly wasn't night and day.
When I ran the numbers through a prop slip calculator, I came up with 23%, which seems a bit on the high side to me.
After evaluating my needs, I've decided I want a good balance between top speed, cruising, and watersports. From what I've read, a stainless steel four blade prop is probably the best overall choice. I haven't eliminated the High Five, but it's cost and benefits may not align perfectly with what I want.
Any opinions on how the following props compare with each other (with respect to my hull)?
- Year: 1998
- Make: Chaparral
- Model: 2130 SS (Limited Edition - I think that got you some faux wood trim, a compass, and a depth sounder... how does that make it "limited"?)
- Length: 20' 6"
- Beam: 8' 4"
- Engine: GM 305 V8 w/ Throttle Body EFI - 240 HP
- Stern Drive: Mercruiser Alpha One
- Drive Ratio: 1.47 Drive Ratio
- OEM Weight: ~ 3150 lbs
- Current Prop: Mercury 21 Pitch Vengeance 3 Blade Stainless(don't know the diameter)
- Full Laden Specs - 6 adults: ~ 1020 lbs
- Gear: 100 lbs
- Full Laden WOT Engine RPM: 4,400
- Full Laden WOT GPS Speed @ 4,400 RPM: 45 mph
- Minimum Laden Specs - 2 adults: 350 lbs
- Gear: 70 lbs
- Minimum Laden WOT Engine RPM: 4,700
- Minumum Laden WOT GPS Speed @ 4,700 RPM: 49 mph
- Mercury Revolution 4
- Mercury Vensura
- Turbo 2+2 TH
- MIchigan Wheel Apollo XHS 4 Blade
- Solas HR Titan 4
- Other suggestions are welcome...
