The short wiring harness on a 703 control box
larsst185
On my 10 pin 703 control box there are two short wiring harnesses coming out of the control box (+ the long one going back to the engine).What are these wires for?Found out yesterday that it has a ground connection, a constant positive and a ign positive lead?.Maybye also a tach output?Is the warning buzzer supposed to be connected here.It came disconnected when I bought the motor used.I bought a brand new control box whan I got the engine so I wouldnt have to use the previous owners mangled wiring harness...
Dunaruna
Re: The short wiring harness on a 703 control box
They are there for dash gauge connections, adapter cables are available for different gauges/warning lights etc.
If you have a tach, it should be connected on one of those short plugs.
larsst185
So I wont need to go all the way back
to the motor to connect my digital yamaha gauges?
pat34
Nope, the long harness that goes back to the motor already contains that connection, so you can take it straight from the control box.
larsst185
does anyone know the part number for this adapter harness?I have both the digital tach with tilt/trim meter and a digital speed meter.I only fint part numbers for later models, 2004 and up
rodbolt
part of your question about the tach will depend on the engine model number. thats all I can say about that.
the red,light green and light blue leads are for a seperate engine trim switch such as a bow mounted switch on a bass boat.
the red,black,yellow and dark grean are for the tach and speedo if using digital yamaha stuff.
for trim and oil alarms and visual overheat idicators you will need the trim harness.
here again part number will be engine model dependant.
