Re: The value of a locking differential
The GM 80 is not much up on a limited slip and when the weights fly apart it doesn't work at all. I've repaired lots and they simply don't last under a heavy foot.
A real locker, like and ARB, will turn both wheels all the time when engaged. I've used ARB's at both ends for over a decade and while expensive, you get what you pay for.
Agreed, the Eaton G80 locker that GM uses is effective but they have a bad rep for imploding. Not terribly expensive to fix in this age of a million here and a billion there but why should you have to.
Depends what you have for a diff.
If you are going to a limited slip you will need a new carrier. You can install an aussie locker in your present 10 bolt. If you install a limited slip (and GM calls its limited slips posi, lockers ect) you will have to accept that if one tire is off the ground you won't be going anywhere. The aussie will give you outstanding traction all the time even if one tire is in the air, but it will ratchet and clunk and lower speeds when turning.
I would go with a high quality after market limited slip for a street truck. You can remove and install the ring gear or swap gearing. Its up to you.
I would stay away from the eaton variety GM80 or anything govloc.
GM does a bad job of calling a locker a limited slip and a limited slip a locker in literature or at least the industry does. You need to look at the glove box code to see what you actually have. A G80 Eaton Locker's purpose among others is that when one tire is off the ground you will go somehwere however their G86 RPO code, Limited Slip, is different and indeed more for street trucks than off road. The G86 doesn't lock the wheels giving you benefit in low traction situations but not to the same extent as a full locker. There are lots of nice youtube videos comparing a lsd to a locker to an an electronic version of an lsd. The locker seems to always perform the task best.
Also then a lot of the trucks that I know where the person bought it used and realized later that it had no locker also tended to have the base 3.42 gear ratio as opposed to the 3.73 more apt for towing and so a full swap replacing the entire axel front and rear with the 3.73 from a salvage yard was more cost effective than buying a locker and having someone put it in or so I understand.
I'm having a hard time understanding why anyone would buy a truck up north and not have 4WD. You couldn't give a 2WD truck away around here..
I couldn't agree more, If you left it running in the wrong part of town I don't think even a car thief would take one here in MN. When I see a 2wd truck or even an suv my assumption is the owner is a transplant from somewhere warmer than MN. When I see them for sale on CL, there is always some half hearted attempt to explain why a 2wd is less costly to fix or something to try to offload it. Suprisingly a 3.73 and a locker is hard to find on some suv's as I learned with my most recent suv hunt. 4wheel drive is an insurance policy you may never need but secretly hope you do.
