I'm changing the thermostat -raw water cooled 2003 4.3 190 HP MERC- I have the service manual#25 My question is on the installation, it says the gasket has continuity rivets Do not coat with Quicksilver Perfect Seal or audio warning temp switch may not work , but then it says to coat it on step #5 in manual and reinstall.I'll give more info if needed.<br /> I know one of you top notch wrenches will help me out, also is there an alternative to the Quicksilver Perfect Seal?<br /> thank you, Celtic Knot
