Thermostat housing
sebas54
Hi, I have 1987 GM 4.3l merc IO. I just replaced the thermo housing with the t balls and it is different then the old one. With the new housing the t-stat doesn't set on top, it goes inside the housing. I looked it up and it seems that I am missing a collar or sleeve? Do I need to get the sleeve. Did I get the right housing. Right now it doesn't have the sleeve and the engine doesn't warm up.
Re: Thermostat housing
Ayuh,... If the housing you're useing needs the sleeve,... It won't work Without it,...
sebas54
Thanks for the reply Bond O!! Always can count on you
