Re: Thermostat-how do I know it's working
Check to see that it heats up quickly enough, if it doesnt it may mean that your thermostat/s are stuck open or not seating properly so it wont quite get to proper operating temperature for a lot of running conditions.
Put your hand on the heads and check that they heat up roughly the same. Often the starboard bank gets a bit hotter faster, ive never worked out why but they shouldnt be massively different.
Dont rev your engine just let the idle do the warming up, you should notice appreciable heat within 30seconds and be quite hot within at a minute. If that doesnt show up any problems you will probably need to test it after running at wot etc with the infra red gun Bob brought up
